L
Lucyonisland
- Messages
- 7
- Vehicle
Hi looking to replace the H frame, which still works, but one of the interior cables has snapped, with gas struts. Looking for advice on suppliers, how to do it, where to attach etc. Thanks Lucy
If you were definite about converting to the gas strut roof sourcing the parts will certainly be your biggest issue. This website has diagrams and part numbers for everything you'd need but as you'll soon see most of the Westfalia stuff is no longer available. Giving a list of part numbers to your friendly VW Dealer parts department might reveal a few but it's more likely you'd need to find a donor vehicle. Seems like an awful lot of effort when the simplest thing may be to source the replacement parts for your H frame and get that fixed.There is a local conversion company who could do the work, it was more me sourcing the correct parts.
You'd never know the cable was there if all is good and healthy. Roof still works, just doesn't feel as stable, hence strapping up the middle joint. Not sure cable can be replaced as it runs internally, where it attaches etc is unknown to me.
The H frame does make a handy drying rack, and as anyone who owns one of these knows there is always something to spend money on.
Thanks for your help.
Have installed now. I decided to keep the H frame to help with stability and a good place to hang stuff!
I had only one cable gone inside the H frame but had to cut the other one because the roof would not go up/down straight.
Happy with the result, cost was about £200 for kit, $92 was postage!
I drilled pilot holes for the self drilling screws on the bottom fixing but they were still hard to drill into the metal!
