s2bear
Hi All.
As I understand it (maybe someone will confirm), IN THE UK, T6s with LED headlamps have a 'travel mode' option in the multi function display which auto adjusts the headlamps for driving on the right. (?)
Can anyone with an LED Headlamp specced EUROPEAN (LHD) T6 confirm if it has the same 'travel mode' option (for driving on the left)?
I'm importing a Cali from Europe and my local UK VW Cali Dealer incorrectly suggested stickers then said I'd have to change the complete headlamps so I gave up there and called VW UK Customer Service, who said that they don't actually know and asked if I'd called my local dealer as they might know
. The European dealer says that nothing has to be done to the LED headlamps as far as they are aware.
To get the vehicle certified here the VCA gives a number of headlight options, 2 of which are:
- Original factory fitted headlights that are, through a standard feature of the vehicle, adjustable so that the beam can be changed from right dipping to left dipping
- Original factory fitted flat-beam headlights (we can not accept a right dipping beam that is adjusted to flat-beam unless that is a standard feature of the vehicle, e.g. done via operation of a lever)
As always, any help is much appreciated!
thanks S2
. The European dealer says that nothing has to be done to the LED headlamps as far as they are aware. To get the vehicle certified here the VCA gives a number of headlight options, 2 of which are:
thanks S2
, besides. Will need them myself for the same reason!
