CaliPuds
A couple of years on, and I now have a different problem with my retro Dubflectas.... I noticed that the driver side one was flapping quite a bit, near the wing mirror. I have tried fitting some more clips, as I had the spare 2 from the original problem, and it is almost as though the Dubflecta has shrunk, but it won't stay attached to any of the clips now - everything is very loose.
I have ended up taking the whole unit off the driver's side and it now won't attach again - it is as though the clips are too wide for the Dubflecta, if that makes sense?
Has anyone else had a problem with the fittings coming loose after a couple of years?
(And yes, I have the thicker laminate glass, but I am not even back at the stage of the window rubbing as I can't even get it back onto the Cali!)
