stephen watson
I'm looking for some advice please. (WG - if you have time I would like to benefit from your extensive knowledge please!)
I got my T6 in February, driving it back from Ireland to the Lakes. I then didn't use it for about a month and found the engine battery was flat. The AA came out, tested the battery, alternator, checked to see if it was drawing current when locked (no) and found everything OK. We concluded that it had flattened because I had been in an out of it quite a few times (fiddling/admiring it!) without driving it. I was surprised that this had happened so quickly and thought I had learnt my lesson - not to keep getting in and out during a period of non use.
Well, the has same happened again - after around 6 weeks of non use, this time with minimal getting in and out. Again the AA man confirmed all was OK - but explained that some modern cars can only be left a few weeks before the battery is discharged enough not to start. I haven't had it checked by VW as both AA men seemed sure they would find nothing wrong. The AA man also said as it has a DSG I shouldn't try and bump start it on a hill.
At the moment, mainly because of work, these periods of inactivity are likely to continue, so it's a nuisance.
I have a couple of questions:
Has this happened to anyone else and does anyone know how long you can leave it without starting it up?
I have fitted a solar panel (from Roger Donoghue) and that works well keeping the leisure batteries charged up. I had thought, but must be wrong, that it would also top up the engine battery. The AA man suggested I get the solar panel wired into the engine battery as well. Has anyone done this and if so is it a DIY job?
