Tried ours for the first time last weekend. Drained it after use. Is that sufficient or do people flush a chemical through to avoid mildew in the system? If so what and how?
Thanks all....
Never put anything in mine apart from clean water then drain after every trip. Been ok for 9 years.Never done it in 4,5y , just make sure you put CLEAN water in and drain EVERY TIME when you get home after a trip. Water standing stil in the tank for weeks means growing bacteria's
Alltough i do got the tablets on my shelf in the garage....but never acutally cleaned the tank , a job i will do within short time now.....![]()
We use our fresh water tank for storing German air.Tried ours for the first time last weekend. Drained it after use. Is that sufficient or do people flush a chemical through to avoid mildew in the system? If so what and how?
Thanks all....
I am afraid to say that we haven't used our fresh water tank since we picked up our SE (new/ex demo) in October 2015 and don't really intend to. We've never used the sink, the tap or waste water tank either. This may seem strange but given the limitations of the sink and the extra maintenance/care needed to look after these facilities, we haven't yet found an occasion when there hasn't been a better and more convienient option. Neither Mrs B nor I would want to drink the water from the tank unless it's been changed very regularly and scrupulously cleaned out between fill ups. That just seems to be too much hassle given the alternatives. We usually end up staying on sites with much better facilities and if it's just a day out then we'll take the washing up home. However if we were to head off to some remote area we would probably reconsider using it for washing and washing up only.
There I've said it.![]()
Hello HC,That i can not understand , agree that if you use campsites you use theire facilities but still the fact you have all this at hand and don't even fill it up is pretty strange .
As i said above i never in 5y did anything special other than fill up the tank and drain it when home...so easy .
Again each theire own , and we try to use a washingbowl most of the times instead of the sink but thats becose it is much more handy than the sink.
When not on campsites but free aires the water comes in very handy and 30l does get you at least 2 - 3 days further when freecamping .Also by filling up the tank we always have water for the dog with us at any time any place witch is crucial for us.
All nothing personal against you that is
I know there are others never use the sink or watertank , some never even coocked in the Cali , some never sleep in the pop-top ....
Now you're talking.20 litres of Bombay Saphire 10 litres of fever few tonic and two trays of crushed ice.....Do not add lemon it blocks the pipes!
Hi I always empty tank when I get home take filler cap off it drains quicker and leave the valve half open on fresh water tank. Never use waste water tank valve is always open .Following on from this can I ask - when the tanks are empty, is it better to leave the valves for fresh and waste water tanks open or closed?
Or doesn't it make any difference.
Open the tap by the Gas Cylinder housing might be a good starting point.I've never bothered draining the fresh water tank or sterilising it in five years, though I did get round to buying some tablets (Katydin or something). It might be a good idea! Could someone remind me how to drain it direct (other than through the waste tank).
But I don't drink water from the tank unless it's boiled, mainly use it for washing & washing up. I buy cheap bottled water to drink straight, though that's mainly because we ran out of water when wild-camping on Jura, which was a bit of a nuisance!
Brilliant, thank you - will give it a go.Open the tap by the Gas Cylinder housing might be a good starting point.![]()
Be aware, it will dribble out from underneath as the drain opens onto the underneath plastic panel, rather than a spout as the Waste tank does.Brilliant, thank you - will give it a go.
