Removing cutlery drawer
Agrestis
Perthshire
Can anyone explain how to remove the cutlery drawer? We seem to have a small leak from the underside of the tap which drips into th ecutlery tray. Think we could easily tighten the tap joint underneath if we can get the drawer out.
Many thanks.
Ours just lifts up at the front and then pulls out. I assume the T6 is the same.
Yes it is. Open the drawer and then lift the front so it clears the rails. You need to be positive but not force it. Then slide the rear off the runners. To replace - pull the runners out and sit the drawer on them. Then push it in firmly. It'll click as it locks back into place.
There are two grips under the drawer, pull them towards you using both hands. Pull slightly and lift. Be gentle ;-)
Buddy
willwander
willwander
be1t0n
Seaview
johnyboy
johnyboy
Moonlight Motel
Moonlight Motel
