sidepod
- Messages
- 6,512
- Vehicle
- T4 PopTop
Appreciate the ingenuity of this. But isn't there a risk that the multiple connections end up bleeding air out of the tyre?Now I know most of you aren't even aware you have a spare let alone check its pressure periodically but for those who are and do, here's a little mod to make life easier.
Apologies for the state of my tow electrics mount. It's on the job list.
Parts available on The Bay. Details on request.
Pod.
Can you re-inflate it from your remote valve? That would be cool.
Well you only mentioned checking the pressure in the OP - not correcting it. Didn't want to assume .......Is this a joke? Must be? Isn't that the point??
Good use of lorry inner wheel valve extenders. I've a slack handful of those left in my roll top from when I retired from full time working, must dig them out and put to similar use. I was about to give you pelters re the corrosion on that bracket but I see it's on your listNow I know most of you aren't even aware you have a spare let alone check its pressure periodically but for those who are and do, here's a little mod to make life easier.
Pod.
