That looks a bit odd to me. Did you have factory tints or was it done by the dealer?Hello All
We've just had the van windows tinted (as they were factory standard) with the following results, does anyone know a way round having an odd shaded window?
Did you have the double glazed windows?Hello All
So the outer glazing of the 2 rear sides and tail gate would be untinted hence the different look?Did you have the double glazed windows?
If you did then the tinting would be on the inner gazing on the 2 rear sides and tailgate. The side (opening) windows are normal single glazed.
So, can you explain why my set up does not suffer this way? See photos above. I have double glazing.Agree , thats what i meant .. the tint problally is the same but it looks diffrent caused by the fact it are two diffrent windows in set up.
I like the idea of pasta and wine but sadly not for me tonight.No clue ....are they standard tinted or afthermarket ?
Is it the same tint as @lennox is showing ?
As i said there are others who reported this also....i try and do the effort using the seach button later. Now it is time for "pasta and wine"
Less than 10 minutes and pasta AND a bottle of wine. Serious stuff there in Belgium.....
Yes if you walked past it would look odd from rear and front quarters.So the outer glazing of the 2 rear sides and tail gate would be untinted hence the different look?
There has been reports on here of diffrence in tints between the sliding door window and the one behind...
It has to do with the fact it are diffrent sorts of window i think ,
Diffrent tickness
Mine is same as yours. See post #2 above.Here you can actually see the rear window has same tint as the window in the door, on the passenger side. and the. And the window in the sliding door is darker, and with the correct tint.
All ours is genuine tinted.
And the windows behind does not suffer strange reflections
Edit: All makes sense to me now.
