Seaside Sussex
Had a trip to Declathon yesterday, so microfibre towels and sleeping bags purchased (after returning the rather large Vango double bag
I bought an electric hob so we could manage hot drink making with no space and now you show me this £3 solution. Hob is going back and hunt for the board begins.View attachment 19428 Added my variation on something many others have done. I bought a simple chopping board to fit the cutlery drawer and provide an extra work surface/small table as required. Cheap and simple![]()
Is the Bose a radio as well as a Bluetooth speaker?That looks handy, can you charge it in the van, i.e., is the charger less than 150watts, I can't seem to find the power needed on the net, or from Bose
Not sure that's correct. The Soundlink mini I have has a 12v charger with a 240v 13 Amp three pin plug on it.Apparently you can, someone in here confirmed it. Comes with a plug that should make use of the leisure battery the black 2pin behind seats.
Its quite bassy which you cannot turn down but very clear at low volumes when listening to Radio 4.
..message ends...
And now off to France to get some wine....?Went to my first NEC show and came away with some nice Brandrup seat pockets, 10m hook-up cable and most importantly some wine glasses!
Any micro USB cable should work. I've charged mine off its cradle, from a phone charger, and with a power bank, varying from 0.5A to 2A without problem. I will be relying on the standard USB ports in the Cali to charge ours this summer.Not sure that's correct. The Soundlink mini I have has a 12v charger with a 240v 13 Amp three pin plug on it.
I just checked my charging connections. There must be different versions about. Mine is three years old now and only charges via a 3.5mm jack at 12 volts. Perhaps the earlier versions are this way. (I would rather it not by the way!)Any micro USB cable should work. I've charged mine off its cradle, from a phone charger, and with a power bank, varying from 0.5A to 2A without problem. I will be relying on the standard USB ports in the Cali to charge ours this summer.
you can get a plug in converter for the inverter socket to make it a 3 pin socket,Not sure that's correct. The Soundlink mini I have has a 12v charger with a 240v 13 Amp three pin plug on it.
You have just introduced me to something else I didn't realise I needed!Karcher OC3 portable washer/shower
Various bits from the club shop
Wow, that looks like it was a hard impact! I hope that you are OK.This week I bought a new friend for my Van/Cali because I had to replace his former friend - gone in a bad accident...He protected us well and brave.
As a result no money left for some Van-things.
What sort of easy folding dog have you got?Just ordered an easy-folding (I hope) dog crate. The soft fabric/mesh type. We've been using one of the rigid wire frame kind, but it's faffy to fold up and stow away whenever we want to sleep downstairs (pooch is delighted with that arrangement, obv.).
BoxerPackardy Spaniel, (Fold-)Flat-coat Retriever and a Crate Dane.
(Working cocker spaniel really).
Its not clear on the unit but its says "12V---0.833A" on the rubber base pad. I'm guessing its a I and not a II. As I said its about three years old now. Still works well though even if charging in the Cali means a cobbled together lead (another!!).Do you have the mini link I or II? The changed the charging method on the II. I've not tested it, just repeating what a fellow on here suggested.
..me..
Thank you Borris, I am okay. We guess the lady had about 90 km/h on the clock or even more and we stood still and I had the same thoughts: my tow bar protected us very good.Wow, that looks like it was a hard impact! I hope that you are OK.
It's just possible that your tow bar may have saved you from even greater damage.
Very nice. Is it a Superb?Thank you Borris, I am okay. We guess the lady had about 90 km/h on the clock or even more and we stood still and I had the same thoughts: my tow bar protected us very good.
Had some kind of neck and back pain however it is gone after some treatments (massage).
And this is my new one. I am happy
