Borris
This fell off the other day. Well actually Mrs B helped it but that's another story.
As I am sure that we are not the first Cali owners to have had this happen can anyone answer the following queries?
Is this trim item normally just glued on? The rear of this item looks like this:
As nothing appears to have broken off I am wondering how it stayed on there for so long.
Also the lower B post trim panel now looks like this:
Should the thin grey plastic section to the right of the hole (next to the rubber door seal) extend right the way up to the same height as the rest of this trim panel or has that been snapped off as well. I have examined the top edge of this upright section and cannot be certain if it had an extra peice or not.
If the trim piece was just glued on and the B post lower trim has always been this shape then I will stick it back on. If on the other hand it and the B post trim are in some way broken then I will attempt to get it replaced under warrantee.
Sorry this is trivial but these little things wind me up no end.
