Days out
I'm expecting that some one has tried this before but I thought it might be interesting to show you a simple idea to warm up the upper environment with the use of an old tumble dryer hose.
You can see that the black B pillar grille is easily removed and one end of the hose clipped in place simply using the corrigations of the hose to keep it in place.
The other end of the hose I had was fitted with a collar that easily can be wedged between the header and the tambour door of the roof system.
So a simple way to push a bit of warm air up to the top. The lower cabin is still warmed by the air that escapes from the rectangular B pillar vent around the circular hose.
