Jabberwocky
Forever young (ish!)
OK, great, thanks.Sorry, didn't mean to imply they were up yet, but are promised.
You have a good point as far as I can see.is the metal in the seal there to aid the seal gripping the roof ? if so couldn't a non corrosive material be used instead ? too simple or am i ?
@Trebor , if it's not obvious from your photos, could you do us all a great service by doing a simple sketch of the cross section of the seal, showing where the steel is, and where it is exposed? It may help us make sense of your images. (Just take a photo of your sketch and upload).
I'm assuming (dangerous) that the cross section is more complex than a simple U, with the steel lying exposed at the bottom.
Trebor, very interesting observations. Thanks for your post. Could you upload your best photos to MEDIA and advise when done so? Also when you have your new seal can you ask your dealer if there are any special instructions for fitting? If there are I would like to see a copy if possible. Thanks JW
Thanks Trebor. What is image 965 (second image on this post) and where is that on the seal or is it the corner of the aluminium roof? It looks pretty sharp to me, and is that paint peeling?The exposed corroded steel is mainly in the base of the U but some other areas . Very difficult to photograph and probably 20/30 spots in the straight front section . The sides and rear are much better . I have posted some photos in media x4 . Hopefully you will be able to see them .
Thanks Trebor, I think I can work out which is which. Very interesting.I have uploaded x4 photos to media hopefully . Old seal ,new seal and roof corrosion . Removing and refitting seal is really easy . Just avoid putting any force on 90 degree weld . Start removing half way down a side .
May have been answered before. Haven't read all previous posts. Not necessarily a Cali fix, just info.someone said they had rust in a seal they had purchased, if so does this mean the metal could be taken out and replaced with something different ?
The metal is an integral part which is the clamping part that holds the seal on, same as in door seals. Quality seals have stainless steel metal clamp which is 'buried' in the seal rubber or plastic.someone said they had rust in a seal they had purchased, if so does this mean the metal could be taken out and replaced with something different ?
How true!The clearest insight into alloy corrosion I have read is in relation to aircraft where every aspect of this issue is critical.
Not much help if a wing falls of and the manufacturer responds with "We are not aware of any problems".
https://www.faa.gov/regulations_pol...craft/amt_handbook/media/FAA-8083-30_Ch06.pdf
Hi leightonjthomasThere doesn't appear to be any type of adhesive under the seal and it certainly isn't watertight. When mine was checked at SMG Cowfold the seal was just peeled back, photos taken and then replaced. Definitely no mention of adhesive.
No. I had a 2013 T5 which had corrosion on the front panel and under the seal. It was examined at SMG Cowfold and booked in to AB Crush before I sold it. I now have a 2015 T5. No corrosion on the front panel but slight bubbling under the seal.Hi leightonjthomasIs yours a T6 Cali ?
Ok thanks for that. I am trying to get to the bottom of whether there is an adhesive holding the seal in place. This could be a powder, liquid or gel of some sort. Specifically for T6 Cali's.No. I had a 2013 T5 which had corrosion on the front panel and under the seal. It was examined at SMG Cowfold and booked in to AB Crush before I sold it. I now have a 2015 T5. No corrosion on the front panel but slight bubbling under the seal.
I pulled a section of mine off the other day, it is only a mechanical grip, no sealants of any kind.Ok thanks for that. I am trying to get to the bottom of whether there is an adhesive holding the seal in place. This could be a powder, liquid or gel of some sort. Specifically for T6 Cali's.
Ok thanks for thatI pulled a section of mine off the other day, it is only a mechanical grip, no sealants of any kind.
I will when it comes back from the bodyshop!This is the reason why more T6 owners must check their roofs as we will not be covered like the T5 owners are. As far as VW is concerned this is only a T5 problem. Cmon fellow T6 owners get out there and check under the seal.
Ok . I've had my second new seal today and just checked it under mag x5 at home before fitting . Sadly as I expected this seal is exactly the same . Visible wire in numerous places in the front straight section of the rubber . This appears to be corroded steel but I'm not entirely sure . It's definitely not aluminium . It's orange almost copper / rust coloured with something that appears to be corrosion . I'll try to take x50 pictures over the weekend . I don't blame my dealer at all . Just had first service today . Excellent service . Clearly there is a big quality control issue here . Naked eye would not pick this up . These are the labels off the latest packaging . I'm off to Merribel in van in next few days and then Dubai ( not in van ! ) so will not be able to follow this up for about a month . Don't know which seal to refit but will have to do it tomorrow with silicone greaseThank you for taking the time.View attachment 18625 View attachment 18623 View attachment 18619 View attachment 18620 Ok . I've had my second new seal today and just checked it under mag x5 at home before fitting . Sadly as I expected this seal is exactly the same . Visible wire in numerous places in the front straight section of the rubber . This appears to be corroded steel but I'm not entirely sure . It's definitely not aluminium . It's orange almost copper / rust coloured with something that appears to be corrosion . I'll try to take x50 pictures over the weekend . I don't blame my dealer at all . Just had first service today . Excellent service . Clearly there is a big quality control issue here . Naked eye would not pick this up . These are the labels off the latest packaging . I'm off to Merribel in van in next few days and then Dubai ( not in van ! ) so will not be able to follow this up for about a month . Don't know which seal to refit but will have to do it tomorrow with silicone grease
