It depends on what size the BBS alloys are. If as I suspect, they are 18, 19 or even 20" rims and the original wheels are 16 or 17", then I think that you will notice a marked improvement in the ride comfort.my Cali came with BBS alloys and the original wheels with Mud and Snow tyres on. I have only driven with the BBS fitted. Do you think there will be a big difference in ride and comfort if I swap them back?View attachment 18534
You probably won't know this but Sheffield is notorious for potholes and poor Tarmac so that is the reason for my post. I drove back from my first trip and only when I arrived back in town did anything start to shake and rattle.A larger sidewall will give you a softer ride but if you're used to the stiffer lower profiles you might find it different on the corners but better on the potholes.
I will swap them and see if improvements are obvious. Then I have a winter tyre issue. Deciding when to re-boot the 4 to normal when I have good new low profiles in the cellar.It depends on what size the BBS alloys are. If as I suspect, they are 18, 19 or even 20" rims and the original wheels are 16 or 17", then I think that you will notice a marked improvement in the ride comfort.
Smaller wheels = taller tyre side walls = a more cushioning effect over bumps. In effect you are improving your suspension.
With 20" rims and a thin smear of rubber around them you might as well be driving a road roller. You will feel every minor bump.
Original listing shows Wheel info as 19, 20 & 22" diameters. Not as low as 18" it would appear.It depends on what size the BBS alloys are. If as I suspect, they are 18, 19 or even 20" rims and the original wheels are 16 or 17", then I think that you will notice a marked improvement in the ride comfort.
I will bear that in mind once I have given the originals a try. Booked in for ThursdayYorkie, I'd be interested in buying the BBS wheels and tyres if you decide they are not for you.
Mark
Should that be "Bling is a No Brainer" ??You're forgetting the Wide wheels law,
"Bling beats sense".
More like "Bling is FOR No Brainers..."Should that be "Bling is a No Brainer" ??![]()
swap the wheels overMust be someone near with an equivalent machine for you to at least be a passenger? No VW centres where you could test drive?
You will be able to sell them wheels very quickly I'd imagine.
..message ends...
I have booked a local garage to swap the wheels over on Thursday. So I just need a trip to try them out. I will report back with my subjective answer.Must be someone near with an equivalent machine for you to at least be a passenger? No VW centres where you could test drive?
..message ends...
I live in Sheffield which is a bit like a war zone. They have a full tarmac replacement plan so stopped doing quality repairs as that is wasting money. So where roads haven't been fully resurfaced its like a third world country.Mine came with those exact wheels, 20". Tyre wear is above average - they're bigger than the supported size, I believe, so cannot be trued exactly.
I also discovered they use different bolts to the spare and my stock wheel spanner cannot remove them. I have to carry two sets of bolts!
I'm happy with the ride though, I'd rather have it a bit firmer and bumpy rather than a bit wallowy!
