F
Flood51
This morning it was below freezing so I conducted this (mostly useless) experiment. Using three Oregon Scientific remote temperature/humidity sensors. I placed one outside the garage, its a detached triple brick built garage so relatively large, one inside the garage 3m from the Cali and one in the Cali on top of sink/burner unit and closed the sliding door. The Cali is parked in the middle bay. I set the auxiliary heater to setting two then turned it off. 30 minutes later I took the following readings outside -1.2c, inside the garage 5.2c, inside the Cali 2.1c. I then used the remote to activate the heater and waited an hour. The next set of readings were outside -1c (the sun had just started to come up), inside the garage 14c, inside the Cali 21c. So my deduction is that the heater also heated the garage and initially the inside of the Cali was colder than the garage it was in.
Probably time to do something more useful with my day.
Admin please move this if it's not in the right section.
