Yorkie
Eventually settled on the quiet site. Was really cold. We used a fan heater but it was a bit noisy. Looked for an oil filled rad to leave on low. But all seemed too tall for boot. Anyone got one that fits under rear bed?
When you're on electric hook-up fan heaters are great - we like to use their electric rather than our diesel! But when we go to bed, we leave the 'onboard' heater on throughout the night on 2 or 3, which is just fine for us. We're not keen on sleeping in warm environments anyway. Cosy socks, a decent tog duvet, and a fleecy blanket is usually sufficient!Eventually settled on the quiet site. Was really cold. We used a fan heater but it was a bit noisy. Looked for an oil filled rad to leave on low. But all seemed too tall for boot. Anyone got one that fits under rear bed?
It was -3.5 degrees so without our fan heater we may have perished.Dangerous things handbooks.
By all means get a CO detector but don't be put off by that. Plenty of us use the heaters and are still alive.
Or you could die of hypothermia instead I guess.![]()
I've had it on continuously for 5 days, 120 hrs in total. Yes the Diesel heater puts out some Carbon Monoxide, CO, BUT be aware that Diesel Engines produce significantly less CO than a Petrol engine. The Diesel heater puts out minuscule amounts compared to your Diesel engine and lastly the CO from the heater is exhausted outside. NO exhaust gases are piped into the interior of the vehicle.We only got the van on Friday and when we read the handbook it said if we use the diesel heater we would die of carbon monoxide poisoning so we're a bit scared to leave on overnight.
When you say topper! Is that an external cover to keep us toasty?I've had it on continuously for 5 days, 120 hrs in total. Yes the Diesel heater puts out some Carbon Monoxide, CO, BUT be aware that Diesel Engines produce significantly less CO than a Petrol engine. The Diesel heater puts out minuscule amounts compared to your Diesel engine and lastly the CO from the heater is exhausted outside. NO exhaust gases are piped into the interior of the vehicle.
So, sleeping in an attached Awning with the Diesel Heater on has a small risk but not sleeping in the vehicle with the side door closed.
You are more at risk sleeping in the vehicle, especially if the roof is down with all the windows closed, or cooking with all windows/doors closed due to CO from cooking but also Carbon Dioxide from normal breathing of the passengers.
Fit a battery CO alarm, for your own peace of mind, use or don't use the heater as required BUT always ensure you have adequate ventilation especially if sleeping with the roof down as you lose the ventilation vents in the canvas. Using a Topper does not block those vents. More ventilation is good. Just turn the heater up if needed.![]()
Yes. There is an Internal Topper available, but it won't keep the canvas dry and I don't know if it allows airflow through the canvas air vents, as I only have the waterproof external one.When you say topper! Is that an external cover to keep us toasty?
Yes, we have one and use it regularly. Definitely keeps the van warmer,quieter and as WG says the canvas dry. You still get ventilation/air movement. Internal toppers are also well recommended but you don't need both. Search for toppers on the forum, plenty of info and opinions, they sell them in the club shop too.When you say topper! Is that an external cover to keep us toasty?
Or even worse, chilled red!As others have said, A CO detector is as cheap as chips, takes up no room and works.
The heater is fantastic, decadence at a press of a button, quite safe to use and just think how difficult it would be to hold a wine glass with frostbitten fingers!![]()
That's fine but you should have a window open 2cms for ventilation as you would build up CO2 drop Oxygen and increase condensation without it.I've just realised that, if cold, I sleep downstairs with roof closed and heater on. I might have a CO detector, but I get the drift that this might not be the safest move?
I'd hate to find my dog is on a par with a canary.....
Carbon Monoxide will not be a problem. I do exactly the same. I use these
https://vwcaliforniaclub.com/shop/product/vw-t5t6-ventilation-cabin-windows-pair
Just 1 is sufficient.
We fitted wind deflectors can drop window a little same effect but cheaperAh brilliant - thanks for posting this. I'd never seen them before and was expecting to have to buy wind deflectors to get around the carbon dioxide problem and didn't really want to.
Either or both. Both have good and bad points. I belong to both and because they both have sites I like I cover the membership costs by the reduction in site fees for members. Also you save on the M6 toll with the Caravan & Motorhome Club and you get access to the hundreds of Certified Locations both register.Hello All,
We have finally, after 3 years of discussion, just bought a 5 year old California SE and it is great!
Thank you for answering many of my questions in your threads already and much of your advice has already been put into practice.
Can i ask what are your thoughts on joining either the Camping and Caravanning Club or the Caravanning and Motorhome Club?
Many thanks in advance.
Craig
we also are in both. Joined 6 months apart so spreads the cost re renewal dates.The VW California Club is the worlds largest resource for all owners and enthusiasts of VW California campervans.
