2into1
Née T4WFA. Now without Cali :(
So my circumstances are changing and once again I'm battling with the dilemma of having a specialised camper and a cheap run around, or going for the simplicity of a single vehicle. I'd appreciate your help in deciding!
The last time I looked at this, I decided to keep the two, but the change of circumstances has tilted the balance again.
I've stuck lots of detail below, but if you don't want to read all that, can you share your thoughts about everyday (particularly LOCAL) use of your Cali? The long distance commuting aspects have been well discussed on a recent thread. I'm on about the parking, maneuvering, 'preciousness' aspects of the everyday Cali use.
More detail for those with time:
So at the moment I have :
- my T4 Exclusive (LWB, 2.7 m tall, quite heavy to drive, Left hand drive, Loo....all round fantastic smallish camper/motorhome).
if you are unfamiliar.
- a £5k non precious Peugeot Partner Tepee
The obvious thing to do would be to get a SWB T5 with pop up roof (possibly Cali.....), but I can't help feeling the T5 is a bit too big for my type of everyday use.
A T5 is 4.89m long, my Peug runabout about 0.5m shorter.
A T5 is 2.28m wide, my Peug about 17cm narrower.
So there are not huge differences on paper, but feel much greater than that in reality.
On the 'maybe' list is a Reimo Caddy conversion
which initially looks similar size to my Peug but is actually only 1.4cm shorter than a T5! (it uses the Caddy Maxi base). It is a useful 11cm narrower than a T5.
Often it's been just 'me and the dog' away on long duration trips. Sometimes with my young daughter for shorter trips. So having two sleeping areas is a basic requirement.
I've a selection of shelters and tents (Decathlon MSH) to call on. I don't use them with my current set-up (which is fab for simplicity) but will probably need them more in the future.
My normal (non camping) life involves carrying around antiques (business) and ferrying my daughter around.
Because the T4 is currently not losing value (perhaps gaining), it's easy to make a financial case that keeping two vehicles isn't punishing financially, but it feels excessive for a single guy to have two vehicles, and I'm constantly aware of the need to keep them both in use.
I'm probably not going to be camping as much as in previous years (probably coming down to somewhere near the average). Quite frankly, it upsets me to see the camper just sat there waiting. But I know I'll miss it when if goes.
