Sp0_0k
- Messages
- 1,246
- Vehicle
- T6 Beach 4Motion
I want to install a second fridge and solving an autonomous charging for the extra battery.
I charge it only from a hookup now but want to charge it from an alternator as well.
Easiest way without serious modifications I had in mind is to get the current from the cig lighter socket. It has a direct connection with alternator anyway when the engine is running.
The tricky part is to cut charging when the engine stops. Should be easy by simply detecting the lowered voltage.
Let say above 14volts in cig socket, the charger is feeding current to the battery. When the engine is turned off and even if the leisure batteries are fully charged they don't give that voltage.
Or maybe there is an easier way to accomplish it all?
