T6 CFO
Mike
Have you tried this site?Wife couldn't find one or with Google search - will use when they appear close to us.
http://findadblue.mobi
Mike
As you will now know it is available from most Fuel Stations now. White plastic cans that have a filling flexi pipe attached, looks like a can of water. Be careful as it is very corrosive so wash any spill off. Euro 5 Trucks have had it for a few years now and is injected into the exhaust to clean out the soot. More bits to go wrong. Trucks go into 'limp' mode if Adblue tank empty, to stop emission system not being used, but I haven't seen if VW's do that as well.Hi - my adblue tank is needing topping up and wondered where fellow owners are getting topped up. I have just ordered 20 litres via Amazon for £28.00 - which i calculate will last around 12000 miles. It all seems the same kit, but the price varies quite a bit. Its all new to me so wondered what everyone else is doing - i assume in time we will be able to top up at the petrol station
Something similar, VW's will not re-start if Adblue level drops below a certain minimum level and I'm not sure but you may not be able to restart despite filling the Adblue tank without being hooked upto the VAG computer system. Maybe a T6 owner can advise if this is the case.As you will now know it is available from most Fuel Stations now. White plastic cans that have a filling flexi pipe attached, looks like a can of water. Be careful as it is very corrosive so wash any spill off. Euro 5 Trucks have had it for a few years now and is injected into the exhaust to clean out the soot. More bits to go wrong. Trucks go into 'limp' mode if Adblue tank empty, to stop emission system not being used, but I haven't seen if VW's do that as well.
I have an Audi Q3 company car which recently ran out of ad blue - I saw all the warnings but thought I had enough to get home and be able to restart the following morning. Unfortunately it ran out of ad blue 1 mile from home and the ad blue 'no start until re-fill' warning went red. Never-the-less I naively didn't expect it not to start the following morningSomething similar, VW's will not re-start if Adblue level drops below a certain minimum level and I'm not sure but you may not be able to restart despite filling the Adblue tank without being hooked upto the VAG computer system. Maybe a T6 owner can advise if this is the case.
I have an Audi Q3 company car which recently ran out of ad blue - I saw all the warnings but thought I had enough to get home and be able to restart the following morning. Unfortunately it ran out of ad blue 1 mile from home and the ad blue 'no start until re-fill' warning went red. Never-the-less I naively didn't expect it not to start the following morningbut it of course wouldn't. I read the manual at this point and apparently it won't start without a refill of at least 5.7 litres so I then had to bob off to get some. I live in the sticks and as expected our nearest garage in Settle, 6 miles away, didn't stock ad blue. Neither did the next nearest garage 20 miles away in Skipton. I knew that there was a VW dealership half way to Keighley so I waited for them to open and bought a 10 litre jerry can of ad blue and added it myself (with difficulty as the valve contraption that came with the jerry can wasn't working correctly).
The moral of the story is a) don't run out and b) get a spare jerry can of ad blue.
You should be able to pop into any VW (or Audi) dealership and get it topped up for you though and they'll most as likely do it while you wait
Good tip thanksI've just filled mine up at the new Gloucester services on the M5. Both north and southbound have pumps at the HGV end of the fuel station. 11.96 litres 69p/l. Van was reporting 500 miles before I ran out.
Works just like a fuel pump, stops when full, so no spillage.
The filler is below the diesel filler.
4500 miles which is displayed on the MFD and seems to drop in 500 mile increments.
It also tells you what the max and min you can fill it up, although both reading the same at the mo, will see if these alter with use.
Not sure I have 3500 left so haven't given it much though until this post.
It stops working and has to be taken to a garage to have its software reset and a refill. But it does put at least 2 warnings up before this happens according to the dealer. Pic of warning light info.
(Off to have a look to see where best to get it from).
I hope you didn't buy any diesel it's 1.27/L at Gloucester that would have wiped out your savingI've just filled mine up at the new Gloucester services on the M5. Both north and southbound have pumps at the HGV end of the fuel station. 11.96 litres 69p/l. Van was reporting 500 miles before I ran out.
Hi old Sid, not 100% but think it means 'text message' as in the text displayed on your MFD and not as in SMS.I see something interesting on this page from the manual. '...and text messages...'
Is there some way in which your T6 will send reminders via text to your phone? This could be very useful (or annoying if you don't like tech).
DOES NOT RESTART! beware..Just out of interest what happens if you don't fill it up? Does the van throw a wobbly and stop or what?
I filled up the adBlue then drove to my local fuel station to get the diesel!I hope you didn't buy any diesel it's 1.27/L at Gloucester that would have wiped out your saving![]()
He is talking Bo***xI bought some from the local car parts store the other day and the man behind the counter informed me that every time you refuel the vehicle more adblue is injected into where ever it goes (exhaust system????). By that he means if you put in 5 x £10 worth of diesel in the tank you are using 5 times as much as if you put in 1 x £50 worth of diesel in. How true this is i don't know, but it might be something worth monitoring.
Its a metered system based on the amount the engine is driven. This video gives a good overview, the layout is different but the method is the same.To be truthful i thought as much. Otherwise you would only see the gauge go down every time you refueled the van, but i wasn't 100% sure.
But just for my own piece of mind could you / would you please state why you feel this is the case.
