JohnnyP
- Messages
- 439
- Vehicle
- T6 Ocean 150
I have had exactly the same issue while away in France, using the switch at the shower connection provided water at the tap but a bit of a pain. I will investigate the micro switch as the fault was intermittent and it could be a relatively simple fix rather than a trip to the dealer.Thanks for that SD5. I did find that the tap came off easy once it was in the open position and a light prise from the bottom of the handle.
Anyway - micro switch seems fine, shorted the connector below the sink and no joy. Switching on at the shower gets the pump going and works as a fix for the sink. Warranty job.....
