Gavinskii
10 minutes ago was at 8:30pm. No solar energy.
12.5 volts is 0.1 volts from full for a leisure battery at rest.
Your battery is 99% full. The fact that the VW panel says 75% is not true. 12.5 volts is small a fraction off full.
As I said above, I don't know how the VW panel calculates "full", but I can tell you with 100% certainty, 12.5 volts is as near to full as possible without being 12.6 volts. I imagine the VW system sees 13.8v as "full" - which is true, but only under charge.
You have had your fridge running all day and more, and your battery is full at 8:30pm in the evening. Which seems ideal.
You have emailed me regarding the AGM batteries. AGM batteries are charged with the same profile as "sealed" lead acid batteries. You can also use the "gel" profile as this is the same, except it skips the equalisation charging phase.
Ok Roger, thanks you are convincing me that maybe my Cali isn't sick!
Out of interest how do I check / change the cell type on my solar set up - just to make sure I am optimised?
