40 mins included taking the passenger seat out?! what electrics did you disconnect, and airbag warning light type issues?Yes, exactly same Ebay link
excellent, thanks for that, worth getting sorted for that price!No need to remove seat, loosened front rail bolts, removed rear bolts and leant the seat forward, all simple and no need to disconnect any pesky wires!!! Honestly very, very simple.
My Webasto fails starting due to low voltage on my 2007 Cali. The Webasto mecanic questions if the charger actually works on the under seat battery. Both batteries were replaced by VW under warranty 15 months ago.If you have a Lion battery fitted, then it has never had a good charge.
The chemistry or Lead Acid, Lithium Ion (LiOn) Nickel Cadmium (NiCad), Nickel Metalhydride (MiMH) , all have very specific charge requirements. LiOn needs a constant current charge and Lead Acid require constant voltage.
As the charger fitted as standard to your Cali is for Lead Acid batteries and so constant voltage, the LiOn battery is being destroyed by being charged in your van.
It is possible that the charger has also been changed, and if so all should be OK. Both batteries are charged off the same charger, so the under seat battery should be the same as the under cupboard one.
Do check that the charger is the right one for both the batteries fitted, and both are the same type and make..
Alan
My Cali is a 2007/8 NoLimit (Special Edition) with 3 batteries,- one in engine compartment, one under the seat and one at the rear. The Webasto mechanic asks if there is a wiring diagram to understand how the 220V charger works.@orusten
The charger does charge all the bateries even the one under the bonnet.....
Don't know how many you got( you say both...so thinking you own a beach? as a SE got three batts) becose can't read any info under you avatar .
Best to add the verhicle type so people can respond in function of that info.
According to the Webasto guys who just fixed my heater/battery problem, the 220V charger (located under fridge) does NOT charge the under-bonnet battery. This is also logical since this engine starter battery is different from the 2 leisure batteries.@orusten
That seems odd. Your man is quite right in curing a volt drop by fitting a larger cable but if the vehicle is original then the problem must lie elsewhere. VW are quite good at this kind of thing.Got the car back from the Webasto workshop since heater failed to start. They found a voltage drop of >1.5V between under-seat battery and heater, (which has a treshhold of about 10.2V ). They fitted bigger wires and new contactors and problem now solved. They also fitted a wire for the Webasto diagnostic under the seat, making it easier to run future diagnostics without dismantling the heater unit. Tested a heater run of 48hrs without problem, display then showed 40%.
Well a few months on and the battery life was still rubbish. Finally got round to checking the leisure battery fuse and it had gone! Ordered a new one - just a reminder to check for anyone having issues re battery life.
One quick question however - would people disconnect both leisure battery negatives before replacing the fuse and reconnecting the positive (as per advice on the dealer electrics guide) or am I overthinking things? Just is a real faff getting at the battery under the chair!
