Bramco
- Messages
- 793
- Vehicle
- T5 Beach
Hi,
Been looking at various options for solar backup and there seem to be lots of kits out there. We have a Beach, so fitting the controller into the jack space seems to be the best option as per the thread -> https://vwcaliforniaclub.com/threads/removable-drill-free-solar-installation-in-a-beach.14349/
One issue with this seems to be the display. All of the kits seem to use the MT50 display which needs to be hard wired in and mounted somewhere and it looks pretty bulky. So while the panel mounting is drill free, the display mounting isn't.
Victron do a controller similar to the Epever MPTT controller and you can buy a Bluetooth adapter for about £45. See here. The Victron controllers also seem to be a bit cheaper than the Epever as well. (Victron seem to be a very professional outfit doing systems up to the size you see on solar farms.)
The Bluetooth adapter allows you to connect to the controller using the Victron app from your phone, iOS or Android, to get data out of the controller and to manage the settings. See here.
Has anyone used one of these?
An additional question I have is what size controller do you need. You see various specs from 10A to 30A. Reading the specs of the controllers it seems as though a 10A controller would be fine for a 100W panel. Is there any reason you'd use a 30A controller?
