Small dots of yellow liquid while parked
N
NZCol
Edinburgh
T6 Beach 150
I noticed this yesterday, defintely new as my garage is pretty clean and the floor is painted. There was some yellow liquid, tasted bitter (I should say i dont alwasy taste stuff i find on the floor!), roughly in line with the middle of the van or ever so slightly on drivers side. Not much i mean a 1/4 teaspoon max, cleaned it up and a similar drop was there this am so something is obviously leaking. Anyone got any ideas ? 14 plate 4motion manual, i wondered if it was poss a leaky seal on the diff.
I would suspect the leaky dif seal as this is known fault.
Thanks for reply, brilliant timing as I am going on holiday !
Check viscosity, and colour of your coolant to rule that out.
Might be air con leak... Trying to chase down similar issue on our 4 motion 2011... V small pinhole leak in air con metal pipe, greenish output... Is the drip off the midline?
Brake fluid tastes bitter.
Something else to worry about ;0)
Have you got Climatronic. I think there is another heat exchanger in the drivers side rear panel so it could be a leak from the pipes leading to this.
If it's the diff leaking.you should be able to see oil around it but it sounds like coolant to me.
I'm not tasing anything leaking out my Cali....i carry a Porta-Potti so i take no risks...:D
If it was a one time drop of fluide i woud not worry , but best to keep an eye on it for sure.
Open every liquid tank under the hood and taste it....must give you an anwer;)
you could put water on them and work out wether it's oil based or water based, that will remove a number of variables from your puzzle.
Thanks all, will keep an eye on it as nothing obvious when up on hoist - Ac all working and climatronic as well. Odd.
Hi, did you find out what this was as I think I have the same issue?
I’d say Air con leak, maybe on the condenser?
I had that on mine a little further back, it was a pin hole in the air con pipe that runs from the front to the back of the van on the drivers side. Got it fixed at a local Air con specialist.
