t4_lad
Its not easy being green...
So, been having a good old look around the van this weekend and seeing what needs to be done…
We’ve several bits of trim that are damaged or missing and I wondered if firstly it exists pieces to fix/replace these? Or has anyone found and good alternatives?
Main elements are some end pieces from the ‘beige’ trim (namely fridge and rear overhead cubby) and the grey edging strip from the sink/hob top.
If there’s this trim available in strips (I did look at the iron on edging strip you can buy, but what i found was not wide enough). The beige end pieces are 24mm in width and the grey edging strip 16mm.
Do you think its possible to get these from Westfalia or any ideas? Cheers
