jason.oneill4
- Messages
- 72
- Vehicle
- T6 Ocean 204 4Motion
Just wondering if anyone has this issue?
If you stand at the rear of your Cali - with the roof in the closed position, try and lift the roof corner on the passenger side. Specifically see if you can get your finger(s) in under the closed roof seal (right in under the corner)? Then try the same process on the other rear corner driver side. I can lift this corner by an inch or so and actually see in under the roof panel but not the passenger side which is closed tightly. VW say this is normal..... Any thoughts? J.
they sait to her that it could be because of the awening.
