Keith Smith
Sorry, but that is not true.The answer to this recurring thread is simple.
The double pole RCD as fitted in the Cali covers the reverse polarity issue.
End of !
End of !
So, if I install a double pole RCD as the incomer to my house I can install all of my switches in the neutral conductor?The answer to this recurring thread is simple.
End of !
Perfect example. I acknowledge that the RCD will stop you getting fried but it is a long way from being best practice or sensible to accept a reverse polarity scenario.Switching neutrals as the live conductor also contravenes regulations and could mean a toaster element for example is live all the time but only heats up when you turn on the switch, not much help when you stick a knife in to dig your crumpet out.
Welsh Gas Posted this link and and i bought one which has been delivered. Good quality with tester.Perfect example. I acknowledge that the RCD will stop you getting fried but it is a long way from being best practice or sensible to accept a reverse polarity scenario.
The original poster was concerned that there may be a polarity error in their van. If there is then it should be rectified. End of !
Being new to hook-ups it hadn't occurred to me that reverse polarity in camp-site supplies is common. Having learned that it is I shall be making myself up a polarity cross-over lead to use in such occasions.
