benArrayx
- Messages
- 163
- Vehicle
- T6 Cali On Order
Hi all, I've been doing lots of reading and thinking around security, while waiting for the delivery of my new van
As far as I see it, there is robbery with keys, or robbery without keys.
For robbery without keys, there are various methods:
1. Key and immobiliser hacking, needs specialised technology and is only available to hi-tech thieves. Search google for 'car thief hack', there are loads of articles about this. These thieves could be defeated by an extra security such as described here.
2. Towing the vehicle. Not sure how the thieves get access to drive the car later, but anyway that's their problem, you've still lost your vehicle. Best protection against this is to park with your wheels turned and the steering lock applied as far as I can determine, also not parking on the street, but that's more difficult when you're away from home, and if you don't have a garage!! Also the same physical deterrents as mentioned in the post linked above (assuming they're obvious!).
Robbery with keys:
3. If the thieves get hold of your keys (either by entering the house, or physically from you), then presumably they will also have the keys to all your physical deterrents mentioned here, which renders them useless, unless they are hidden - but hiding them stops them being a deterrent to towing for example. That's unless you keep the keys to your physical barriers separate from the van keys, but I for one wouldn't do that, it's already difficult enough keeping track of 1 set of keys!! In this case, you are screwed since they have access to everything with the keys and can do as they like.
In the latter case, the only thing that could stop the theft would be a system that requires further knowledge to start the van, either hidden physical protection, or 'virtual' protection such as a hidden switch, immobiliser sequence, or a visible pin keypad such as the Autowatch Keyguard. These used to be really fashionable about 20 years ago, but I hardly ever see them anymore, not sure why not??
So, the only sure protection I can see is a keypad, or a hidden physical device that will stop someone for long enough, even though they may have the key for it. Bearing in mind that 'long enough' may need to be hours if you are not at home and are away from the vehicle.
As such, I think I'm going to be going for a keypad, although I'm not clear on the warranty position - I'm sure this must be supported since so many hot hatches used to have them, I can't imagine everybody was willing to break their warranty. Or unless anybody here can give a good reason why they're not a good idea!
Robbery with keys:
![IMG_20160102_121617[1].jpg IMG_20160102_121617[1].jpg](https://vwcaliforniaclub.com/data/attachments/9/9723-a5369c33684bd87fa6f70d0ac2c1fabf.jpg)
![IMG_20160102_121551[5].jpg IMG_20160102_121551[5].jpg](https://vwcaliforniaclub.com/data/attachments/9/9724-69bd4289191e5cc0ef349af4ddf255b3.jpg)
