2CV67
I notice that Control Panel Display Failures are a recurring problem on this forum & the French forum I also watch.
Recently, somebody (Pulsart) on the French forum described a DIY repair & several others have now reported success with this method.
So if you have the problem & don't fancy spending several hundred pounds on a replacement, it may be worth a try. (At your own risk!)
The instructions are in French, but the pictures should be enough & you can always use G**gle Translate or such like.
http://www.t5calif.info/forum/viewtopic.php?p=63687#p63687
Scroll further down for continued instructions in a subsequent post and a similar repair by a recognized forum "expert" (Abilly).
The principle seems to be to use the screen frame to keep the ribbon contacts in good compression via solid & elastic spacers.
Although a soldering iron is shown at one point, the contacts ARE NOT RESOLDERED, just warmed to about 90°C & pressed down.
Please report here if this works (or not!) for you.
Note: this method does not involve cutting the connector ribbon, like a previously-posted method here:
http://www.instructables.com/id/How-to-remove-and-re-attach-LCD-Ribbon-from-a-PCB-/?ALLSTEPS
I have not tried either method myself (& don't have the problem yet...)
