Would be very interesting if you could document building and installation of the sub, with measurements and pictures.Hopefully have underseat sub install done soon.
Bloody magnificent!
Just completed stage 3 upgrade, 10" 2 ohm JLA 10TW-1 sub and JLA xd500 amp. Cabinet from Absolut5. It's a snug fit but I managed to get it all fitted cleanly under the driver's seat. The transformation in the soundstage, sound quality and sheer power is absolutely stunning. When run from the measly 18w from the HU the JLA component speakers were disappointing, when amped with a clean signal they really come alive. I'm tempted to fit another amp to drive the rears now!
Very pleased that I did this, cheers @nclarke8 for the pics and tips of your install.
Stage 2 complete here, front and rear.
Couple of notes for anyone considering this:
- Mdf speaker rings are available on ebay
- You'll need 4.8mm x 16mm or 20mm rivets to refit the front rings.
- There's plenty of space to mount crossovers behind the dashboard. Behind the canbus interface on the right, and to the left of the glovebox are good locations.
- Don't skimp on sound deadening.
- Instead of resetting the door card clips (see removing/refitting the door card instructions) you can just buy replacement clips on ebay for pennies.
- I chose to fit the new tweeters in the old mounts which required some Dremel time.
- You may want to port the rear cupboard and / or angle the speakers forward to improve the soundstage
- The benefit of upgrading your rear speakers is very small IMO
- There's no point in reusing existing speaker wiring for fronts, it's actually easier to rewire with new speaker cable
@reserves Yeah, 6 per door but buy 10 and you'll have 4-5 left over after doing both doors. Some clips seem to destroy themselves on removal, others are fine. If anyone's contemplating a speaker upgrade then send me a PM as I've spare L-brackets and rivets i can post you.
I've just bought a JL Audio xd200/2 amp to drive the rear speakers, fitting that this weekend![]()
that's a lot of speaker! (pricey too!). what amp / sub are you planning?
L brackets: I had to buy 25 of these to fit the xd500 to the Absolut5 enclosure http://www.screwfix.com/p/angle-braces-self-colour-19-x-19-x-1-2mm-pack-of-50/67412
