rookeryview
- Messages
- 156
- Vehicle
- T5 SE 180
Reading about another house break in and key theft story on the forum, I thought, "that's enough", lets sort this out.
So I've got 2 ways here for you to prevent your pride and joy being taken, even if you hand the keys over yourself !
Here's all you need;
Method 1
This is based on an idea previously posted, but I've added a padlock!
Turn the drivers seat round.
Fold the back of the seat forward as far as it will go with the knob, and then push the seat right up against the steering wheel.
Next, take off the plastic cover behind the seat, and underneath there are a set of holes in the seat rail, perfectly drilled to take a simple padlock. Imagine the stress building up when the seat won't move!
(I did contemplate driving the Cali by sitting in the passenger seat, but I don't think this would be very successful if you were in a rush, or wanted to drive more than a few hundred yards.)
Method 2
I noticed that under the accelerator pedal, there's a metal stop, which has a gap big enough for a padlock to go through (2015 model at least)
When a padlock of the right size is put through the loop, there's no way to push the throttle down as it jams the motion. Again, it's nearly impossible to see, let alone cut off, and in the panic of escape, this will certainly ward off the thief, and will probably collect some forensic evidence of the perpetrator in the failed process. On the seat, if you are lucky...
These ideas are so crafty, that you probably don't really want someone breaking into your house in order to fail to steal your Cali, so I suggest some sort of notice hanging on the steering wheel saying something like "This vehicle can't be driven with the keys alone" will give someone scoping you out, at least one extra chance to pass you by.
I agree that these are a little fiddly, but either will pretty much render a theft impossible.
It's alright relying on your insurance to bail you out, but this isn't really a solution as your NCB will be marked, you may not get the full value back, and you'll loose a lot of time waiting for all this to be sorted out while you wait for a new Cali to be delivered, so the actual loss is a pain and well worth preventing.
If we all did these things (and more) as a matter of course, then they would leave us alone for good. That must be worth the effort, surely?
Sleep easy friends!
Method 1
Method 2
Sleep easy friends!
