VIP Discount Back2You Subscription Free Trackers for the Cali
Martin
Martin
Administrator
Admin/Founder
Bourton on the Water
20% Discount for all VIP Members
With these subscription free trackers there is no need for wiring as the Back2you tracker is powered by durable rechargeable battery which provide up to 90 days of use between charges, whilst no installation costs or monthly fees means that the Back2you tracker is an affordable choice.
Functions include geo-fence alarms which will alert you if your campervan moves out of a specified area, and movement alarms which will let you know if your vehicle moves more than 200m. For the peace of mind that you can always keep track of your motorhome or caravan, come to Back2You for the highest quality caravan and motorhome GPS trackers.
  • No installation costs
  • No monthly or annual subscription fees
  • No awkward wires, simply charge the device when necessary
  • Large rechargeable battery which will need recharging once every 90 days
  • Ideal for protecting caravans and motorhomes in storage
  • Strong magnets on the tracker allows you to attach your device securely to any metal surface
  • Tracker comes equipped with a charger and external antennas
  • Isolating fuel supplies and activating alarms can be done remotely using a relay
  • Real time tracking allows you to check the position of any of your devices at any time using Google maps
  • You can set up a movement alarm which will notify you if your caravan moves more than 200m
  • If your unit is jolted or disturbed you will be notified with the built in shock sensor alarm
  • An over speed alarm can be set which will alert you if your motorhome is travelling faster than the pre-set speed
  • A Geo-fence alarm will notify you if your vehicle is removed from a pre-programmed area
  • Support for map viewing on mobile devices (Google Maps, etc) – just click the link
  • No need for additional antennas as it comes equipped with highly sensitive GSM and GPS antennas
  • Your unit can be permanently installed using the GSM and GPS power supply leads
  • Width 55mm, Length 95mm, Height 40mm, Weight 325g
  • Search for the latest Back2You apps for android and iPhone in your app store
Best of all NO monthly or annual subscription fees
20% Discount for all VIP Members - Click Here for Code
-See more at: http://www.back2you.com
Does anyone out there have one of these and what are your experiences of them?
