sidepod
- Messages
- 7,055
- Vehicle
- T4 PopTop
Chaps,
Just curious if anyone out there has changed a wheel in anger?
I had to yesterday on my Caddy. It’s the same concept as the Cali. I’ve taken my Cali spare wheel out several times but only in the confines of a nice warm dry barn.
What a nasty process. Truly unpleasant on the hard shoulder of a busy motorway.
For starters you need to lay on the ground to undo the two bolts holding the spare wheel cradle (not an ideal scenario on your own on the motorway) Only one bolt needs to be removed, the other loosened. The vehicle in question is only 2.5 yrs only but the bolts were already quite stiff.
Once free, the cradle is quite heavy and drops to the floor of its own accord. Keep your fingers out of the way. The alloy spare wheel was face down. In other words removing it is impossible without scraping the alloy face across the tarmac, ruining it in the process. The non removable tow bar didn’t help. Perhaps this is one reason for a detachable tow bar?
If your Cali is lowered, forget it. You’ll need to jack up the rear end.
So to conclude. I would recommend familiarising yourself with the process in a nice controlled environment like your driveway and regularly lubing the two bolts holding the cradle. In addition I’d take the spare out and wrap it in something that will protect it from damage when you drag it out.
I wouldn’t try replacing the flat in the cradle on the motorway. Just chuck it in the van and do it later somewhere safe, remembering of course to bolt the empty cradle back in place first.
Spod.
Spod.
