I don't think a small amount of " droop" is unusual after a couple of days. The van should automatically adjust it periodically. Mine dropped as much as in the picture in just a couple of minutes.
The newer Cali's do correct the diffrence between the two sides automaticly .I don't think a small amount of " droop" is unusual after a couple of days. The van should automatically adjust it periodically. Mine dropped as much as in the picture in just a couple of minutes.
2. To remove control panel the manual suggests using a screwdriver and easing out the panel, what you need is two not one tools and NOT a screwdriver. the panel is held by the old type car radio flexible tabs, what you need is 2 thin metal strips, one each side to allow forward and then downward movement of the panel...gently.. I used cutlery two thin knives worked well.
The back of a coffee spoon works perfect to remove the control panel.
Also if you have problems with the roof or any other thing controlled by this panel, try first with engine ON to press and hold the "back" button for at least 15 seconds. It will reset any faults and maybe it will just start working well. Some roof failures are not due to faulty parts, but just electronic errors. If you operate the roof without engine ON you risk that it goes in error.
Re: Changing roof elevating jack
Hi just followed some very comprehensive instructions on how to change the jack. i thought all had gone well until final stage and upon re~pressurising system to raise roof from a mid position, with all connections made hydraulic and mechanical the hydraulic fluid just leaked out from rear connection and followed drain line to rear of van and drain.....
so what i am after is information on refilling the reservoir wherever it is and any ideas from members. i have checked that the hyd lines were not trapped and blocked etc perhaps just unlucky with the jack?
may have to go to dealer after all.....any dealer out there done this job before, mine cant even change the rear brake light without making a mess of the job..thanks![]()
Anyone know why roof sagging (on one side) might occur regularly and worsening...only to suddenly stop doing it? Definitely not the re-tensioning process! Can hydrolics do this? Bubbles?
Use the search function " shaggy roof"
Proceed with caution searching for "shaggy roof"![]()
Hello,Re: Changing roof elevating jack
NOT MY WORK BUT VERY USEFUL, JUST ADD.....WHEN REFITTING HYD CONNECTORS ENSURE YOU HAVE FITTED SMALL RUBBER SEALS FROM OLD JACK OR NEW ITEMS.
OK the solution was easy but expensive. The system consists of a pump and 2 hydraulic rams. Pump at front of roof and the rams on each side situated outside of the canvas. The rams can be removed without taking apart the rest of the system and can be removed independently.
The rams work on a push me pull you principal the direction is operated by the valve sensors. When the pump is not operating the system is balanced, i.e. no pressure in the system. (But I think the roof would need to be supported for this to be completely true).
Conversations with VW dealers ranged from, bring it in and we will diagnose it to there is not much diagnosis that can be done. Try replacing the ram first £225 + VAT if that doesnt work then its the pump. £900 + VAT. I have access to the official VW manual and that is of no help and is not precise with partial dismantling either.
So I bought the ram (both sides are identical and same ram used from outset) and worked out how the system was likely to work. Armed with that info here are the instructions for changing a ram.
It is a simple and clean job.
Tools needed.
Acro prop. 2 pieces clean plywood about 30cm square. Set of Torx sokets. Good pair of pliers. Usual screwwdrivers. Circlip pliers protective sheet about 1m square, Allen keys.set of good steps or work platform. 2 people are useful. Replacement cable ties.
Method.
Elevate roof about halfway. Prop using acro prop positioned between front seats using the plywood top and bottom to spread load. Protect trim further with clean cloth if necessary. Working on platform remove the 2 black plastic covers. Place some protective sheeting between the mechanical system and the canvas roof and have this ready to hang down under the ram when remove. Just in case of fluid spill. I did not experience any.Remove the 2 grub screws with an allen key from the rear hinge mechanism and also using circlip pliers the circlip from the from hinge remove the pin. This circlip does appear to be soft and bends/fatigues easily. Take care or have a new one for reassembly. It is in the inside and a pain!! Remove any further securing screws/bolts from the ram. Cut the cable ties securing wiring and hydraulic lines. Not the routing or take a photo first. DO NOT CREASE ANY OF THESE LINES. Take the new ram. DO NOT ATTEMPT TO MOVE THE PISTON IN THE RAM, I KNOW IT WILL BE IN THE WRONG POSITION!! IT is pre filled with fluid do not upset the balance. Using pliers remove the shiny metal hydraulic line securing clip by pulling along direction of ram on the old ram. Also slide out the electronic sensor housing. Gently pull out line from its location. Do exactly the same for the new ram except there will be a brass pin instead of the line. Place the line into the new ram and replace clip. Now do the same for the other end of the ram. Make sure everything remains clean. Carefully locate the new ram into position. Ensuring the acro stays in place operate the pump in "open roof direction" very carefully a little at a time to push out the operating arm in the new ram. When it lines up with the locating hole in the mechanism locate. Replacement is a reversal of dismantling. Take care with the circlip. Cable tie on the lines ensuring original routing and NO CREASES.
I then operated roof in the opening direction. The pump continued a bit longer than normal whilst the system purged and balanced itself.
For me the original problem solved and not necessary to replace pump so cheaper! Hope someone finds this useful. any question please get back to me. Sorry its long winded but!! If you have to force anything you are doing it wrong!
Ali B
Thank you for taking the time to share.Re: Changing roof elevating jack
Tools needed.
Method.
Ali B
Hello. My van is a 2009 and I have a sagging roof one side. I would need to pay someone to fix the issue. I've been advised it could just be a leaky seal.Re: Changing roof elevating jack
I had hydraulic failure on the drivers side a few days ago - severe sagging. From this and previous posts i can see it was the jack. Initially i could not get the roof down but with improvised help from the AA I managed to get it down without reverting to the awkward manual solution and tie down straps. Can see from this and other posts the jack is £300, my question is has anyone had the repair done by a specialist hydraulics repairer instead., is it a part they could acquire more cost effectively.. My van is 2009 and out of warranty so looking at other cost effective options before goingto the dealer.
I'm afraid the Member you are replying to was last seen in 2016.Hello. My van is a 2009 and I have a sagging roof one side. I would need to pay someone to fix the issue. I've been advised it could just be a leaky seal.
Did you find an expert to do the job for you? And if so who were they? Many thanks
