mikeringrose
- Messages
- 85
- Vehicle
- T5 SE 140
Hello all,
My beloved 2014 Cali broke down this weekend. I want to make sure I am not going nuts. Please help and any technical advice would be welcome.
When I park up I use leveling chocks and I normally turn off the engine, put it in gear, and if the cali is trying to roll backwards off the chocks, I would put it in first gear. Then i put the handbrake on. Turn the engine off and let the clutch up. Then release the handbrake and the Cali moves back a tiny bit before stopping. I then turn the drivers seat round and put the handbrake back on. This has worked fine for 38 nights camping so far.
On Friday night I did the same but the Cali rolled backwards off the chocks turning the engine over (the wrong way I think). Then when I started the engine there was a hell of a bang and clatter. The AA man said the auxiliary drive belt was shredded and wrapped around the crank pulley. I have just spent a day being recovered to home before the Cali goes on to VW Kettering.
My concern is VW might simply change the belt without investigating the possible gearbox problem. The AA men said it sounds like a problem with the gearbox which needs investigating as no vehicle ought to roll the wrong way against the correct rotation of the engine.
Can anyone help or advise please?
Regards
Mike
Regards
Mike
