mrteegrassgill
- Messages
- 24
I found some recommendations on here for a Peggers rear suspension kit http://www.pedders.co.uk/pedders-suspension-vw-t5-transporter-rear-suspension-kit_p22541206.htm for firming up the rear of the cali (esp in the case of 4 motions which carry extra weight) and improving the towing.
Just had the kit fitted yesterday by my local garage at a cost of £48 for an hours labour.
I haven't towed with it yet but I am expecting good things given previous posts.
I found the standard springs were not strong enough and left the trailer pointing nose down and the cali tail down which made it driver poorly.
However in normal driving I note the following
Handling is better, less roll and bounce.
Makes the steering sharper
The springs are stiffer but they still handle the bumps well and there is no detriment to the ride quality.
Only down side I can see is that it raises the back so the vehicle does not sit flat. It looks far better externally as previously it always looks down at the back, however this obviously makes the interior unlevel. However I have never camped in the cali once where I haven't had to use ramps so not really worried about this.
As a result of fitting these springs I definatley thing the 4 Motion Cali is undersprung on the back. It is like a different vehicle now.
I highly recommend, perhaps even if you do not tow anything.
