andyinluton
- Messages
- 7,802
- Vehicle
- T6.1 Ocean 204 4 motion
How about starting a list of carparks that on the face of it should be ok but should actually be avoided at all costs?
My nomination after this mornings experience goes to Tobacco Dock in Wapping London. I had a meeting to attend in wapping so googled for parking & found this. its multi-storey with 2m head room £5/day 200 metres from where I needed to be & outside the congestion charging zone (Just). Sounded perfect.
On approaching the entrance I thought that the height barrier bar looked low, it was but I still had at least 2 or 3mm of clearance so plenty of room.
Then came the first problem, the unattended ticket office (its now pay & display) had a grille covering the closed window, this grill projects about 150mm into the entrance route at door mirror height, with the mirrors folded up I had approx 5mm clearance each side but made it through unscathed.
We then get into the multi-storey carpark itself, there is a one way system with separate ramps for up & down, these ramps are approx 300mm wider than the cali with 150mm high kerbs which extend for a good length after the ramp has finished, with a car parked in the bay opposite the ramp it is impossible to get round the bend in one go, the first one I had to go backwards & forwards a couple of times, the second ditto, the third was impossible a van was parked in front of the ramp & I had no option other than to go over the kerb- result 1 gouge out of a spoke on the rear offside alloy. The fourth ramp was ok.
Getting out the car park - 20 minuets of twirling the steering wheel to go down just the 2 floors resulted in just the one further nick in the same wheel. Then we get the actual exit this is set on a curve to the left with the same huge kerbs to make sure you keep in lane, you get half way round the curve & you find the box where you used to put in your ticket to raise a barrier. Well the box is at exactly door mirror height & even with the mirrors folded (&touching the box) it is impossible to get past it without the rear nearside wheel mounting the kerb. Result a further wheel damaged & a scratched door mirror.
So there we have it 12000 careful miles with pristine alloys destroyed in one car park. Still it gives a great excuse to get some 18" sportlines.
Any others I should avoid?
