Worktop Glass Front Trim, How Is It Fixed Here?
I
Ian Reynolds
Fleet
T5.1 se 180
1000169819.jpgI need to remove this bit of trim as its come unstuck on one side, but it's attached in the middle somehow?
Is there a screw under the rubber round stop as I can't see any other place it could be fixed?
Any help appreciated.
I would not think there is a screw under the bump stop.
I think the metal trim is glued onto the glass panel.
Does it move freely on the outsides but rotates around the middle?
Is the description of your California correct? Is it a T7? Then you should still have some warranty?
But I think your picture shows a T5/T5.1?
Hi, yeah it's a T5.1.
It's loose on the left, moves a good 5-8mm and it's defiantly fixed tight in the middle, seems more than just stuck tight but happy to learn
