Wind deflectors
Hotel du van
Hotel du van
Chichester, West Sussex
Hi,
I bought some wind deflectors for my T5 Cali. They are from Van- X and are the ones that stick into the window channel. The problem I have is when I close the window it automatically re opens because it’s sensing something. Has anyone else had this problem and what can I do? Thank you.
Mine had two small metal inserts each side which seem to prevent the window from sensing the deflector.
It worked for two years but recently stopped doing so so took the deflectors out.
Good luck.
Yes......the deflectors are for single glazed front windows. My is laminated with two panes of glass. On the passenger side there is a slight bubble in the glass. I've cut as much out as I dare, but this one is problematic. The drivers side is fine.
