Sorry Now Sold Westfalia Translift Sliding Side Rack, VW Club Joker, California Exclusive, Nugget. £350
Ch1pbutty
Ch1pbutty
Burgess Hill
T5 Cali on order
Very rare!
Rack slides down for easy loading.
Have sold our club Joker, hence can’t supply a fitted photo.
Comes with various fixing cradles for surfboards, SUP’s, Kayaks, Masts, paddles. Plus additional strap mounts.
Locking caps are missing, but does not affect operation in any way.
Collection only from Burgess Hill as longest section is 230cms, hence courier will cost an arm, leg & kidney
The Westfalia "Translift" sports equipment rack system is the ideal solution for safely and conveniently transporting sports equipment on Westfalia High Roof.
Set up for a T5.1 / T6 VW Club Joker, but should also fit T4 VW California Exclusive & Ford Nugget High tops as they share the same factory threaded mounting points (2 on the roof, 4 on the side, covered with a black plastic plug)
No more complicated maneuvers – with the Translift system, loading and unloading takes place at window height, without any climbing. Thanks to the sturdy slide rails and user-friendly mounting system, you can easily and safely load your kayak, bike, or other sports equipment onto the roof of your vehicle.
Your benefits at a glance
Ergonomic loading at window height : No more awkward climbing – you can easily attach your sports equipment at window height and then pull it onto the roof.
Robust and safe
The Translift system is securely mounted on the vehicle's existing attachment points and ensures that the sports equipment is securely fastened .
Flexible installation : The system can be installed on either the left or right side of the van – provided that the awning is not fitted. If an awning is fitted, then the rack must go on the non awning side.
Complete set
All necessary parts are included so that assembly can begin immediately.
Ideal for high roof
Easy transport of your sports equipment
With the Westfalia Translift system, transporting kayaks and other sports equipment is child's play. The ergonomic sliding rails allow for quick and convenient loading directly at window height. The best part: no awkward lifting – the rails do it for you!
Reliable security
The Translift system securely attaches to the vehicle's mounting points . The robust construction ensures that your sports equipment stays securely in place – even during longer journeys or over rough terrain.
Included in the set
The set includes slide rails , a connecting rod ,, and all necessary fasteners. This makes installation a breeze , so you can get on your way quickly.
IMG_2545.jpegIMG_2540.jpegIMG_2547.jpegIMG_2551.jpegIMG_2549.jpegIMG_2552.jpegIMG_2550.jpegIMG_2539.jpegIMG_2548.jpegIMG_2546.jpeg
Fitted photo for reference. Will only fit fixed high top roof:
