Vw t4 2003 cali Abs Esp control module dault
Coxy_si
Apo11o14
T4 Hightop
I need help with ABS / ESP control module on my 2003 t4 cali. The ABS warning light is onand I get “ Code 01422 traction control hydraulic pump” on my reader.
There is a 5A fuse that keeps blowing when ever I skid on gravel fier example. It’s removed in the attached pic.
If I disconnect the 25pin abs cable. The fuse stay ok. So I’m thinking it is a short in the control module. But how to get it out for repair without removing the brake lines?
If I remove the screws it comes out a bit, but not enough.
