Tap and control panel
Gina-B
Gina-B
Exeter
T6.1 Ocean 150
Haven't posted for a while but thought i might share today's experience which was/is a problem solved.
On just day one of a three-nighter, we arrived at Charmouth CCC site and needed a cuppa before anything else. Turned on the gas and went to fill the kettle but the tap did not deliver. I'm not very techi or electrically minded (although I did rewire a house many many moons ago) but discovered where the fuses were (under the front passenger seat) and removed one of the two 5amp fuses. Looked ok. Tried the other 5amp fuse. All ok. So I decided I might need the garage to take a look when I got home. There is a tap on site so we were not to go without our cuppa.
Decided to put the electric roof up only to discover that the control panel was dead! Oh no! Not good. I knew that (after researching the forums here - thank you) that the two 5amp fuses were for the tap pump and the control panel. Not knowing what else to do, we took the two fuses out, swapped them round and put them back. Bingo! everything is now back to normal.
So, any ideas as to why this happened?
Brownbetty
11K
Mama Mama
Mama Mama
simplybikes
simplybikes
simplybikes
