andybeary
Bit of a mess, if any pointers please drop them below but my thinking so far
The other item then is also from reading is that the EHU will be older AGM battery profile but heard will still charge just need to check when full and disconnect (hopefully wont need with the new x2 ecotree lithiums) but have the Delta 2 for big appliances.
Removed the rear leisure battery use as more storage and just tie up the cables and ensure saftly insulated.
Have i missed anything or any recommendations i have missed?
I am waiting on some connector lugs as ran out so probably going to keep it like this for another week.
- replace the split charge relay with feed to Orion xs dcdc input,
- output 4awg from dcdc will go into a 60a fuse then to the positive terminal on leisure under passenger seat
- New 4awg wire connection from under driver seat positive via 80a fuse to fist leisure via 80a fuse.
- 4awg orion ground output to victron smartshunt (500w) in minus side along with the original negatives from factory cables as well as then new drivers side awg4 negative
- connect direct from victron smartshunt (500w) 4awg to the negative on under passenger seat
- connect the original ignition start cable to the orion H input (i think this is right) - going to try and buy a vw connector so can adapt it so keep OEM cables.
- If all works then i will add the cerbo gx link to the victron smartshunt and orion xs dc dc
- Bring MPPT from rear to front to connect to leisure battery
- add a VE cable to the cerbo GX from mppt in rear via 5m cable (attempt to find route)
- Ensure connect the seats back before starting up as i know the airbags and stuff need to be connected before connecting the batteries up
