Accessories For Sale Sold Calicap.de California sliding drawer 760mm deep £250
Tamanddave
Tamanddave
Worthing
T6.1 Ocean 204 4 motion
Best thing we bought for our T6.1 Ocean, makes for rapid and easy access to boot contents.
Pull-out tray for all California variants with a factory kitchen. This is the 760mm deep version, the seat in the T6.1 is 5 cm further back than the T6, so it is moved 5cm forward to fit the tray. I wanted the bigger tray.
Substructure is made of CNC-welded aluminum, the aluminum shell is 3 mm thick, the corners have been sanded clean.
Simple, light and screwless attachment to the rail system of the T5 / T6 / T6.1. The attachment is done with original Volkswagen locks.
It doesn't matter if two or three floor rails are installed. The third (middle rail) is not relevant for mounting. Only the two outer rails are used as with the seat.
Very robust heavy-duty rails lock in and out automatically.
Aluminum 80 mm on three sides and 40 mm edge on the front.
A black removeable fleece mat is fitted in the tray base. The back is rubberised for slip resistance.
Weight: 18.5 kg
Height from the van boot floor to the inside of the drawer is 19mm
The tray is very stable and can be loaded with 100 kg with an even distribution .
Hi,
I am in Worthing West Sussex
I'm interested. I'm in Brighton. Will PM.
Kevin English
Kevin English
Kevin English
P
Accessories For Sale Pull out rear Drawer / Tray
Gillos
G
Tim Hook
Tim Hook
Tim Hook
