Rear Cupboard Door replacement locking mechanism (T6/T5) kit - the little springs
jonnystrong2000
jonnystrong2000
London
T6 Ocean 204
Help Please - Hi all, so I purchased the hinged door repair kit (rear door - above the gas bottle). I cannot fathom out how and where the little springs go, assume hard up against the top and bottom plastic handle and their fittings near the top and bottom of the actual handle, any idea which way around they go, and where they ‘lever/push’ against between the handle and the fixing? TIA, Richie
Ok, I worked it out, there are little skinny slots in the plastic housing for the ‘large’ leg to be seated! - replacement mechanism now fitted and working - not, the catch mechanism needs the ‘hook’ bit to be facing the right way to secure into its slot when at rest!
