The VW Transporter 180 bi-turbo engine (
CFCA engine code, 2.0 BiTDI) requires
7 liters of engine oil. It's crucial to use an oil that meets the manufacturer's specifications, such as
VW 507 00 for the CFCA engine. After filling, always check the level with the dipstick after the engine has been run to operating temperature and allowed to settle, ensuring it is between the minimum and maximum marks.
Steps for an accurate oil level check:
- Warm up the engine: Run the engine for a few minutes to get the oil to operating temperature.
- Turn off the engine: Switch off the engine and allow a few minutes for the oil to drain back into the sump.
- Check the dipstick: Pull out the dipstick, wipe it clean, reinsert it fully, and then pull it out again to check the level.
- Adjust if necessary: Add or remove oil as needed to bring the level to the correct position on the dipstick.
