My DIY solar install..
Dizzy
Dizzy
Beds
T6.1 Ocean 204
After much mulling towards the end of last year we decided to add some panels to Dizzy. We contemplated getting kits from a variety of different suppliers. In the end we decided we would have a go at building our own system, we could take our time souring components from where ever we wanted.
We wanted flexible panels and went for three Renogy RSP100DL-36-UK - 100 watt panels hoping we could get them on the roof with a cm or two to spare. To mount them we sourced some unequal L aluminium , had them cut to size and rounded off the corners and drilled out some 8mm holes. The tricky bit came with the mountings to the van tracks, in the end we got some coach bolts with square mounts cut out some stips of ali drilled holes and squared them off with needle files, bolts fitted in nicely and we stuck them in with some flex adhesive (the same stuff people sometimes use to glue panels down).
The panels themselves were bolted onto the frames with a run of the same bonding down either side. So here you go all three assembled ready for install.
Underneath them we stuck some foam strips to protect the van roof.
We got a couple (male and female) renogy 3 to 1 connectors along with some mc4 cables and corresponding connectors. annoyingly there was a fault on one of them so i sent them back for a refund and swapped to a 3 way cable splitter, that actually mounted better under them on the roof of the van.
Next bit was the coiled springy cable and getting a suitable waterproof connector, this was frustratingly challenging, ended up with a deutch DTP 2 core. Which did work pretty well in the end.
Mounting up and in through the gromet in the tail gate as per other installs, omg, getting that cable through to the cupboard was a right PITA but once in connected up to an isolator, into the Victron 100/20, connected onto the leisure battery and off we go.
We've been away for a 3 nighter completed off grid early march and i am pleased to say worked a treat.
Now just considering whether to go with an ecoflow delta 3 but am a bit concerned about space requirements in the boot.
So how much did it all cost ? Well i wont go there in too much detail but i think approximately £550-600 or there abouts.
We had a load of fun doing it and that was all part of the challenge.
D
Interesting - can I ask what were the dimensions of your aluminium strips, including thickness?
25.4mm x 12.7mm x 1.6mm​
Was surprised how much it cost tbh. Had them cut to size by supplier.
Still got 2 left and a curly cable surplus to req.
Can you tell me how to connect one of these panels to the curly cable ? I have a solar camper solutions set up and the bloody panels is shot (just bought the van ) they want £350 for a 100watt panel which Renogy do on Amazon for less than. £100 plus cable which I guess isn’t comparable with mine on the Curly cable
Are you happy with 1.6mm thickness? I am trying to avoid panel hitting the roof with vibration when driving. 3mm thickness is also available.
They seem stiff enough, I used sikaflex to stick the panels on to them but only the middle two thirds, then used m6 stainless dome bolts with nylon nuts on either end. With the foam strips they seem to be fine. Foam was 10mm thick and quite high density
We went to b&q to see what the flex was like and decided it was OK.
Here are the plugs. Check the size, but look the same:
We connected single MC4 cables out the splitters into a DTP.
After sizing them cut them down to about 80cm. We got a Deutsch DTP Series 2 Way Connector Plug & Receptacle Kit – DTP04-2P DTP06-2S , i also bought some extra pins as i was sure to need some practice. These things seem pretty good and can be assembled and disassembled, watch videos on YT.
The MC4 cables were ok into one of the receptacles , nice tight seal and i didnt use any shrink tube. The curly cable needed stripping back to bare the two conductors, i ended up putting some adhesive filled shrink tube on before i crimped, then once assembled into the receptacle shrank it down, like the one in your picture.
below is one i practiced on from a slightly thicker cable
HTH
D.
Thanks - just to confirm that there is nothing beneath the panels (apart from the aluminium bars at the long edges), ie they self-support?
One more (hopefully) question on your setup - any noise from panels when driving?
Is your spare curly cable for sale? Have you dimensions?
