My Cali is breaking !
heathensofmerica
heathensofmerica
Rangemore
T6 Beach 150
Hi all
Got a 58 plate Cali ocean.
We’ve had the cruise control stop working, now the window wipers and the sliding door!
The door sounds like electric motor (or whatever it is) engages but then door doesn’t pop out to slide. I have reach inside to use catch inside to open door.
Is there any way to fix these issues at home ?
Thank you
After you check the fuses look for rodent activity. Might explain the CC and window wipers. Did the failures happen around the same time? Do you store the Cali for long periods without using it? Spray some silicon into the door mechanism which can get gummed up over time.
Hi all
Thank you
I would say the Body Control Module (BCM) is a likely candidate given the symptoms, it located behind the lower dash panel on the drivers side (uk) - have you had an water ingress issues and/or new windscreen fitted?
I cheap diagnostics tool would give you a good indication.
Hi all
Thank you
Yes almost certainly can be fixed by a competent diyer.
There are threads already on the forum that will help you identify the issues and fix them.
Use the search function top right - spyglass icon on the top banner next to your profile photo / icon
Here is a few search thread to get you going
Have you had the battery run flat or low?
The van been sitting?
The randomness of these items can be bought on by low battery.
