Lubricating the sliding door 2018 Ocean; removal of external centre trim
P
Phil57
Cambridge
T6 Ocean 204
Hi everyone
The sliding door on our Cali has got progressively stiffer - I've never lubricated it.
The top runner is easy, as is the lower runner, both cleaned & silicon applied and the door is noticeably easier, but still too stiff.
The middle runner is hidden behind a body trim panel, which has the 'OCEAN' script on it. I can see one screw for removal at the front of the panel, but cannot see how to remove it. I expect there to be a second screw somewhere - help please!
I think it involves removing the interior panel, rear offside, by the bed.
In the info section is a full body manual that will explain all.
Ours was getting stiffer a while back and I noticed half a forest in the bottom mechanism which I swept out and it improved the ease of moving no end. Thanks for your advice. I’ll lube the top and bottom when I get a moment to see how that affects it.
Hi everyone
Held on by 2 screws, one is under the rear light fitting, and multiple trim clips which frequently need replacing.
Thanks guys, what is the panel named?
And just so I buy the correct parts, please can you give me the name of the panel clips?
Many thanks
Phil
Thanks! By way of contrast our Caddy has 2 doors, no trims & can be cleaned easily by hand.
Hi everyone
WD 40 does the trick!
