KevH
Wave at Ruby if you see us
I am sooooo tempted to ask whether your wife is available to those of us who are so clearly using the wrong techniqueI think most of you are using the wrong technique on this. Totally.
My approach is as follows:
As night falls and bed time approachs you carefully put away the cabin table, open the sliding door and step out into the darkened campsite. You walk quietly and firmly to the washroom. Clean your teeth and use the loo as required. Do not rush. Return to the van. By now all the blinds will be drawn. Carefully open the sliding door and you will find the bed pulled out to its full extent and your wife lying in it reading a book. Carefully lift in & position the porta potti which lives outside during the day. Then step inside, close the door, pull down the window blind before changing into your pyjamas and join her.
This is the method I have used for many years and I hope it helps.
