How are VW Tailgate racks stolen?
Haven't got the HexLox yet, but got some bolts and die off ebay. Needed to cut about 1cm of thread, which works fine on a T6 rack. It seemed that 50mm bolts are much longer than necessary. Could probably get away with 40mm or less, which would have a shorter shank and maybe need less cutting.
The cut portion will corrode badly however. Will need to treat it.
You could buy some fully threaded And stainless steel
After temporarily removing my rack I took the chance to apply a clay bar to the paint followed by a resin polish. The rack is now refitted using replacement bolts and Hexlox security inserts. I also used a Hexlox in one of the bolts on the horizontal bar to prevent them being removed. Very pleased with the result.
I'm happy to report my Bike Rack is still in place and the Hexlox are fine. I've just received a message from them with their Black Friday offer. No use to me now but here it is if you can take advantage:
The Black Friday Code is: protectlove2020 and the best place to start is
probably here: www.hexlox.com/blackfriday
I checked our dealer fitted T6 VW bike rack yesterday, the mounting bolts are Torx with a centre pin, but the bike rack torque tool is a plain hexagon (Allen) key.
Am I missing something - an adapter perhaps?
The cheapest die I found was on eBay (a mere £4.95 - I'll probably only use it once), and I had to choose M6 x 1 or M6 x 0.75. Hence my queries about pitch size.
Hi Deccauk, could i possibly buy your M6 die with 1mm pitch off you if you don't need it again - so I know I have the right tool for the job :)
Hi, I know this is an old thread but I’ve read through and I can’t work out whether the hexlox solution only works on T6 bike racks or whether it’ll work on the t5 one too? Thanks
You may already know this - Hexlox, https://hexlox.com/en-gb , is a generic solution that prevents anyone from using a simple Hex spanner to undo the bolts and take away your bike rack. It has a special coded key that blocks anyone from using a hex spanner without they key. see this video on how it works -
To fix a hexlox, you need to ensure that there is sufficient space for the hexlox key to lock the hexlox into your hex head bolt.
Don't see any reason why it would not fit a T5 bike rack as a hex spanner will need to fit into the space to undo the hex head bolt.
If your bike rack, for some reason has any other bolt that can be undone with a simple scredriver etc, then change to hex head bolts and use hexlox ... or any other security bolt with an uncommon head pattern.
